(0)| 5/21/2025 6:12 AM | |
Joined: 8/3/2009 Last visit: 1/9/2026 Posts: 16629 Rating:
Hello Andreas__ the problem is, that your Smartphone has probalby a totally different resolution and ratio than your HMI. you could check in a Start Screen with a script (UI.GetClientInfo) which resolution does the Client have. Then you can decide what to do. For example to call a different startscreen with a different picture screen layout to fit the smartphone resolution better, or the regular startscreen for the local Panel RT. Bye Murof |
