(0)| 7/29/2025 9:06 AM | |
Joined: 8/3/2009 Last visit: 12/19/2025 Posts: 16612 Rating:
Hello AutoGen_8392a I think the error message indicates that some data for the transfer is missing. I had the same messages while loading a Unified project to a MTP. This was on a test system where I had not installed the Unified Comfor tPanel images. -> you should install the Unifieed Comfort Panel Images for the TIA Portal and the Image version you use on the panel and also check which Device Version you have set in the TIA Project for your panel: https://support.industry.siemens.com/cs/de/en/view/109825605 Bye Murof |
