9/10/2025 4:07 PM | |
Joined: 9/27/2006 Last visit: 9/14/2025 Posts: 12408 Rating:
Hello; To start on an informative note, here is a link to the S7-1513 Pn manual, showing the basic configuration of the redundant CPU system. Your error message seems to say that there is no valid pendant connections with your CPU. Does your setup resemble the screenshot in the attachment below? https://support.industry.siemens.com/cs/ca/en/view/109972215/169547584267?dl=en Can you give us a sketch of the way you are trying to connect your Moxa module to the CPUs? Hope thus helps, Daniel Chartier |
