7/2/2019 10:20 AM | |
Posts: 12 Rating:
Hi all, My colleague has asked me to export a DB from TIA so he could import it into SCADA. He gave me a small guide (attached image) and a Siemens software download link. However, after having installed SIMATIC SCADA Export for TIA Portal, I see no menu item "Export to SIMATIC SCADA". Could someone help me on that? |
7/2/2019 10:41 AM | |
Posts: 12 Rating:
I do have TIA Portal V15.1. I just have no idea on how to use and where to find "Export to SIMATIC SCADA" |
7/2/2019 10:58 AM | |
Posts: 12 Rating:
OMG, man you saved me :D Thank You! |
9/4/2025 1:20 PM | |
Joined: 8/19/2025 Last visit: 9/4/2025 Posts: 1 Rating:
After having installed SIMATIC SCADA Export for TIA Portal, I also see no menu item "Export to SIMATIC SCADA". PLC menu right Mouseclick at the end of the menu shows the item “Propeties”. The list of installed components shows the Export to SIMATIC SCADA. |
9/11/2025 8:20 AM | |
Joined: 8/3/2009 Last visit: 9/12/2025 Posts: 16409 Rating:
Hello do you have installed the correct version for the TIA Portal version you use? It should appear if you do a rightklick on your S71200 or S71500 PLC: Bye Murof |
