(0)| 1/8/2026 12:03 PM | |
Joined: 8/3/2009 Last visit: 1/16/2026 Posts: 16644 Rating:
Hello ma'moon_gaber if you want to hae access from an Excel Sheet to winCC you can use VBA as OPC UA Client to get access to the WinCC OPC Server (LINK) If you want to write data directly from WinCC to an Excel Sheet you can try to use the MS Automation interface with VB Script. There is an simple example in the WInCC Help System. It would help to understand your usecases better if you could give us a few more details Bye Murof |
