(0)| 1/9/2026 8:55 AM | |
Joined: 8/14/2020 Last visit: 1/14/2026 Posts: 451 Rating:
Hello AutoGen_9310244 Which WinCC Unified version are you using exactly? Take a look at this link for the Online Office procedure: https://support.industry.siemens.com/cs/de/de/view/109828368/153856539915?dl=de Please tell me at which step you're stuck. Best regards, Costanza |
| 1/9/2026 10:35 AM | |
Joined: 2/16/2022 Last visit: 1/12/2026 Posts: 2 Rating:
Hello Costanza I am using WinCC Unified PC V19 Upd4. I followed all the steps, and as said, in the online version of excel, the add-in works. When loading the add-in in the desktop version of excel, I get the weird layout as seen in my previous post. Regards, Louis |
| 1/9/2026 10:51 AM | |
Hello LouisVR Which version of MS Excel is installed on your PC? You need at least MS Excel build 16.0.6769 or higher. https://support.industry.siemens.com/cs/us/en/view/109828368/168643757579 If you are using an older Excel build, you will need to update Excel to a higher build. Best regards, Costanza |
