(1)| 2/16/2010 5:22 PM | |
Posts: 5822 Rating:
Dear Andreas, I must admit, I have never done it but as I know it from this FAQ Drives ES uses PG Routing and this works with the by you used Hardware even so you use a SINAMICS... and the FAQI found was about Masterdrives. Seen from STEP 7it has to work. If I think about the VPN solution directly to an Ethernet Interface on a SINAMICS this works too... but how it works if you use PG Routing over another PLC??? I am not 100% sure. Maybe eventhis will help you to get a step ahead. Best regards J_Bell |
| 3/17/2010 6:18 AM | |
Posts: 3 Rating:
Thisis a feature of Step 7working withStarter. Here isour internal "How to" document that provides a step by step solution for your need. AttachmentHow to connect to a VFD via remote Ethernet connection.pdf (527 Downloads) |
