(0)| 6/7/2010 11:27 AM | |
Joined: 3/21/2006 Last visit: 1/10/2026 Posts: 10247 Rating:
Hello, Even without Amperolyzer V3.0 you could detect Profibus failure. In the beginning you could check if you send commands to the drives. Also is possible if you receive commands into the drive. About how to use Amprolyzer look at documentation there AmprolyzerV32.zip Best regards, Hristo Mihalev |
| 6/7/2010 5:56 PM | |
Joined: 9/27/2006 Last visit: 1/11/2026 Posts: 12480 Rating:
Hello Hezzens; It would appear that what you are looking for is a combination oscilloscope/protocol analyser. You could look at Profitrace (and associated products) from Procentec: http://www.procentec.com/products/#profitrace It is one of the most powerful Profibus diagnostic tools I have seen in operation. Hope this helps, Daniel Chartier |
| 6/9/2010 2:43 PM | |
Posts: 2964 Rating:
Hello... Can you check the profibus cable sheilding and connectors.....haveit is installed properly. there steps to check the connector and it is already posted in fourm. I am attaching the details of the same And there is BT200 equipment avialble from Siemens for checking the profibus cable and the connecttor. Hope this infromation may be useful...... Ekalavya AttachmentChecking procedure for Profibus Connector.pdf (464 Downloads) |
