(0)| 11/9/2010 1:04 PM | |
Posts: 13 Rating:
ya thanks. now tell me that I am working on Distributed fail safe syatem and I am using AI module of(6es7 336-4ge00-0ab0) but while compiling it gives an error Splitted from Logic development in S7 V5.4 SP4 but want to open in S7 V5.4 SP3 . |
| 11/9/2010 2:41 PM | |
Joined: 9/27/2006 Last visit: 12/24/2025 Posts: 12472 Rating:
Hello anup; Please confirm that you have all correct versions of software required to work with this fail-safe modeule (look at the requirements in the following FAQ): http://support.automation.siemens.com/WW/view/en/28570675 … If used together with S7 Distributed Safety - STEP 7 , V 5.4 SP 3 + HF3 or higher Hope this helps, Daniel Chartier |
| 11/10/2010 10:23 AM | |
Posts: 13 Rating:
Thanks Dchartier. Yes I installed all software and please find the attachement. |
| 11/10/2010 4:13 PM | |
Hello Anup; You list states you have Step 7, v.5.4, SP3; but I cannot tell if the recommended HotFix3 has been applied, based on the release number code. Might I suggest that you download the latestversion (SP5) for Step 7 v. 5.4? Service Pack 5 for STEP 7 V5.4 and STEP 7 Professional Edition 2006 Tell us if this clears your problems. Hope this helps, Daniel Chartier |
