(0)| 12/13/2010 5:42 PM | |
Joined: 3/21/2006 Last visit: 1/10/2026 Posts: 10247 Rating:
Hello, Have you looked at CAx-data in the Service & Support Portal . Perhaps will helps you. Best regards, Hristo Mihalev |
| 12/13/2010 7:57 PM | |
Joined: 7/2/2008 Last visit: 12/21/2025 Posts: 929 Rating:
Hello Ferdisko, If you mean something like what is attached then it's possible with EPLAN P8 without add on modules. I'm not very clever in EPLAN but I think you should add dxf files as graphical macros for all thepartsyouthat youuse in wiring diagram (It's very time consuming). Then you can place the parts you have usedon a mounting panel. They all should be linked with your parts list if you add parts to what you use in wiring diagram. If you need a 3D model (and more) then you should take a look at EPLAN Cabinet. Best regards, H-H AttachmentEPLAN print job1.pdf (617 Downloads) |
