(1)| 1/10/2011 2:30 PM | |
Posts: 2964 Rating:
Hi.... If you have replaced the encoder on the motor internal side you should aligned it...have you done the same??? Alarm 300610" Rotor identifiaction failed"..... Does the encoder what you have replaced is Incremental / Absolute? There is a procedure for aligning the encoder.When ever you replace the encoder the current should get matched if this is not matched you will find error... ERN:1381 https://www.automation.siemens.com/doconweb/content.asp?item=13231&cd=sinumerik_simodrive_04_2010_e&scope=all EQN 1325 https://www.automation.siemens.com/doconweb/content.asp?item=13245&cd=sinumerik_simodrive_04_2010_e&scope=all Check it out... Regards, Ekalavya |
| 1/11/2011 11:58 AM | |
Posts: 2964 Rating:
Hello... 1017 is startup assistance this accepts only number 1. Looks like this is not Siemens motor.... Try toget the motor data sheet of the specific motor what your using it and then enter the datas poperly i am attaching you the alarm description for the reference check it out... Regards, Ekalavya Attachment300610.pdf (725 Downloads) |
| 1/12/2011 12:21 PM | |
Posts: 5 Rating:
hi dear all how adjust incremental encoder RON 285 With control system 840d? why don’t save information in NCU after adjust?thanks |
| 1/12/2011 6:13 PM | |
Posts: 2964 Rating:
Hi... Inceremental encoder - referecence required when ever machine is switched OFF and ON Absolute encoder- Reference not required. One time referencing....motor is installed if motor / ballscrew is distrubed you need to do it again In your case how your referencing??? through bero Check out this link this will be useful regarding referencing /tf/WW/en/Posts/52279#top Regards, Ekalavya |
