(0)| 7/12/2011 5:17 PM | |
Posts: 48 Rating:
Dears, we have Siemens dc motor 135 kw we replaced it by another motor 119 kw, and adjust the new motor parameters on the simoreg converter according to the motor namplate ( armature current ,armature voltage, field current,....). itis enough or we should make autotune? if we should make autotuninng, how we can do that exactly? thanks Splitted from P350-P354 change - autotuning required?. |
| 7/13/2011 4:40 PM | |
Joined: 7/8/2009 Last visit: 6/7/2025 Posts: 1977 Rating:
Yes You have to perform Auto tunning after changing Motor Parameters How to perform it? - Check out start up procedure in Manual, there you will know all procedures step by step Regards Devesh Vithani |
I dont Like people driving Fast, thats the reason I overtake them ;) |
| 7/16/2011 2:24 PM | |
Posts: 48 Rating:
please i need the parameter for make autotunning. i search in the start up procedure but i didnot find. thanks |
| 7/17/2011 12:11 PM | |
Posts: 8092 Rating:
Hello, Please check the attached file. AttachmentQuick start up.pdf (404 Downloads) |
| 7/17/2011 9:18 PM | |
Posts: 48 Rating:
deer, thank you very much for P 51=25 it means that the motor should free mechanical load? |
| 7/18/2011 7:10 AM |
Posts: 8092 Rating:
No deer!!!!!!!!!!! DEAR |
| 7/18/2011 8:20 AM |
Joined: 3/21/2006 Last visit: 10/16/2025 Posts: 10239 Rating:
<OFFTOPIC> DEER = DEEP - It might be. |
| 7/18/2011 8:39 AM |
Posts: 8092 Rating:
YES YOU ARE RIGHT. MAY BE DEEP. |
