(2)| 11/25/2011 1:11 PM | |
Posts: 2964 Rating:
Hello... |
| 12/9/2011 11:03 AM | |
Posts: 8092 Rating:
Hello, You need to have RS232 cable. Please refer the attachement for pin connection. On PG Simocom U must be loaded. Then connect PG with RS 232 cable to simodrive & start Simocom U. You will see window (please refer the attachement). here select the option as serach for on line drive. It will automatically detects & displays On line drive. Hope this shall help you. Good luck. DEEP. AttachmentSimodrive cable connection.pdf (2167 Downloads) |
| 12/9/2011 11:08 AM | |
Posts: 8092 Rating:
here is another one. |
| 12/15/2011 6:40 PM | |
Posts: 5 Rating:
Thanx Mr.DEEPSTR2010, problem solved. your attachment ws helpful ! thank you again regards chamma...
