(1)| 2/11/2016 2:11 PM | |
Joined: 12/18/2014 Last visit: 1/10/2026 Posts: 36432 Rating:
Here is a simple example of using the PI controller. The input I1 is switched between manual and automatic mode of the controller. The setpoint can be changed via the display. AttachmentPI-controller.zip (422 Downloads) |
| 2/11/2016 2:47 PM | |
Posts: 17 Rating:
Thank you ixo. I'll take a look but it will certainly help. |
| 2/11/2016 6:32 PM | |
A small example of the power on / off with a hysteresis range. The threshold values can be set via the display.
AttachmentON_OFF.zip (386 Downloads) |
| 2/12/2016 10:26 AM | |
Posts: 17 Rating:
But first i just want to replace the sensor and make an on/off system to see if it works. Tank you |
| 2/24/2016 8:48 AM | |
Posts: 4757 Rating:
New question published by Le Test !! is split to a separate thread with the subject Best Ultrasonic sensor for a tank of water. Best regards |
| 2/24/2016 1:50 PM | |
Posts: 120 Rating:
here you are program for example
AttachmentCircuit Diagram1.zip (400 Downloads) |
