(0)| 6/20/2017 12:11 PM | |
Posts: 34 Rating:
Dear sir, I use Siemens SIMATIC IPC847C computer with order code 6AG4114-1NP32-2PX6 , we face problem in site as below we need your help to solve it : Unexpected shutdown happened to computer many times (This computer act as server ), please check attached event viewer message and blue screen error .Attachmenterrors.zip (274 Downloads) |
| 7/28/2017 9:01 AM | |
Joined: 10/18/2012 Last visit: 12/1/2025 Posts: 225 Rating:
Hello ENG.ABDUL, this looks like a software problem to me. It may be caused by some external, unsusual hardware or an old driver. I would consider to make a full backup of the system with some backup tool, e.g. SIMATIC Image & Partition Creator. Then reinstall the operating system and see if the problem disappears. Sadly this approach is a little time consuming, but it ensures that your hardware works correct. You may also check if your IPC runs with the latest BIOS. You can get the latest version for your IPC847C at https://support.industry.siemens.com/cs/ww/de/view/48791896. regards, |
