(0)| 8/7/2017 8:38 AM | |
Posts: 14 Rating:
I think if you want Apache to run on your IOT you have to build your own image. If you want to avoid that you can use node.js which is already installed on the example image V2.1.3. There are many tutorials on the Internet that help you to set up your own webserver with node.js and its Web-Framework express. If you want to, you can check out this. I developed this as an example webserver for the IOT, in the documentation you will find some advice on how to use node.js. |
