(0)| 8/31/2017 7:38 AM | |
Posts: 5521 Rating:
hi Nicholas2077, have a look in the manual of S7-1500 Webserver, page99: SIMATIC S7-1500, ET 200SP, ET 200pro Web server
I guess you need a certificate for it. hope this helps, regards,
| 8/31/2017 9:23 AM | |
Joined: 3/25/2015 Last visit: 3/12/2025 Posts: 96 Rating:
| 8/31/2017 10:41 AM | |
Hi, It seem I found the problem, if I disable Global security setting in CPU properties, both OPC UA and Web Server show 'Global security not enable, only limited function'. But if I enable 'Global security setting', the OPC UA panel show global security enabled' but web server panel still show global security setting not enabled, as image3 show, I still confuse how to enable web server global security setting enabled. |
