(1)| 10/4/2017 2:40 PM | |
Joined: 4/28/2015 Last visit: 4/24/2025 Posts: 3345 Rating:
Hi,, I do not see any other possibility to have the data in Eclipse apart from the two you mentioned. You do not need to programm a whole OPC UA client in C++ by yourself. There is an open source implementation: https://github.com/FreeOpcUa/freeopcua. You can use this one and adapt it to your application Best regards! |
| 10/5/2017 2:07 PM | |
Do you use the Eclipse IDE with the SDK V2.1.3 and the Plugin V1.2, which you can download here? Best regards! |
| 10/5/2017 2:25 PM | |
Posts: 5 Rating:
Yes, that's exactly what I use; with Eclipse Neon.2 |
| 10/9/2017 8:22 AM | |
Posts: 5 Rating:
Hi, that's the same error I get. I would really appreciate if you could check this. Thanks in advance! |
