(0)| 9/22/2017 9:11 AM | |
Posts: 36 Rating:
Hi, sometimes happens to make a wrong network configuration, modifying the /etc/network/interfaces file, and then the IOT doesn't connect to the network. How to reset/change the network configuration without rewrinting the entire sd card. I've tries using the debug UART cable, but this lead to a Shell that doesn't allow any action on files. Thanks! ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 9/25/2017 7:50:43 AMNew subject after splitting |
| 9/25/2017 7:52 AM | |
Joined: 4/28/2015 Last visit: 4/24/2025 Posts: 3345 Rating:
Hi, you can't write files using the UART cable? Can you please post the error message that appears when you try to do so? Best regards! |
| 10/20/2017 12:42 PM | |
Posts: 36 Rating:
HI, problem solved writing a new sd card. Thanks for help |
