(0)| 8/3/2018 10:20 AM | |
Joined: 12/18/2014 Last visit: 12/25/2025 Posts: 36372 Rating:
When the key switch (I24) is switched on, the message text for the password input is released. The password is stored in counter B007. The range is from 0 to 999998. The ON parameter corresponds to the password. In the OFF parameter, password +1 must be entered. Example: Turning off the keyswitch will reset the password. If you forget this, there will be an automatic logout after 10 minutes. AttachmentOwn_password_in_message_text_(0BA8.Standard).zip (327 Downloads) |
| 8/3/2018 1:51 PM | |
I'm sorry, but I do not know what else to explain. I've changed the password to 1234, started the simualtion and created a screen video. Sometimes pictures say more than words. AttachmentPassword.zip (327 Downloads) |
| 8/4/2018 10:55 AM | |
Is your request thereby solved? |
| 8/4/2018 12:02 PM | |
Posts: 87 Rating:
indeed it is, currently wiring up the hardware to run a simulation regards adrian |
