(0)| 2/1/2019 11:05 AM | |
Joined: 7/16/2015 Last visit: 9/15/2025 Posts: 1 Rating:
Hello Sometimes we have the default 8016 and we are in the position window and stopped. By what is the fault triggered? Is there an encoder fault check? The displacement is started and no encoder position. Thank you ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 2/1/2019 11:39:38 AMNew subject after splitting |
| 2/4/2019 9:15 AM | |
Joined: 4/28/2015 Last visit: 12/5/2025 Posts: 400 Rating:
Hello, which technology object (TO) or PLCopen (motion control) function block (FB) is generating this fault (ErrorID)? Is it all the time or only sometimes? Do you use the right configuration parameters for the encoder? Maybe this FAQ will solve your problem:
| 2/4/2019 11:09 AM | |
Hello, did you also check the communication...? <TO>.StatusSensor[n].communicationOK = TRUE |
