(2)| 3/10/2018 8:44 AM | |
Joined: 11/29/2011 Last visit: 2/4/2025 Posts: 1362 Rating:
Hi, String is a complex Data Type. If you have issues with reading complex data types in a 3rd party system you could brake the variables down and transmit it that way. so you transmit the characters byte by byte. See the Editing text strings and input and output in STEP 7 and WinCC |
- What you read here, please check with manuals and your requirements. |
| 3/12/2018 9:50 AM | |
Posts: 41 Rating:
Hello AutoGen_8579465, you could try DB3,S8.10 for reading string variables. DB3 -> the Block number S -> string representation 8 -> the offset and 10 as the length of the String variable let me know if that worked for you. |
| 6/23/2020 3:10 PM | |
Joined: 4/28/2015 Last visit: 4/24/2025 Posts: 3345 Rating:
Do you mean this post? I gues this should work as it worked when I posted it. Best regards! |
| 6/23/2020 9:45 PM | |
Posts: 47 Rating:
It did thank you! |
