1/22/2009 8:56 AM | |
Posts: 1 Rating:
I have a laptop with Vista and i have some problem to install Siemens software on it.Is there any solution for this or do i need to go for a laptop with Xp. |
2/1/2009 6:25 AM | |
Posts: 133 Rating:
Hello Sebmalex! Of couse yuo can use Step7 in Vista. You just need Edition 2006 SR3! thats it!)) |
2/1/2009 3:33 PM | |
Joined: 9/27/2006 Last visit: 9/16/2025 Posts: 12409 Rating:
Hello Sebmalex; Attached you will find a Siemens document discussing the compatibility of Step 7 (in different versions)and different Windows OS, and also the compatibility of Step 7 with versions of the optional packages offered by Siemens. You will find insidewhich versions of Step 7 can be used with Vista. You also have to understand which version of Vista works with Step 7. Here is how the document describes Vista for use with Step 7: -Vista: Microsoft Windows Vista 32bit Ultimate or Business -Vista SP1: Microsoft Windows Vista 32bit + Service Pack 1 Ultimate or Business Other editions of Vista will not support Step 7. Hope this helps, Daniel Chartier AttachmentSTEP7_Compatibility_en.pdf (879 Downloads) |
