(0)| 1/29/2021 4:14 AM | |
Posts: 1 Rating:
Dear friend, Have you fixed problem with fluctuation of RTD signal? I am facing the same matter but so far, we can not fix this matter. Sometime RTD signal was fluctuated and make our equipment stop. It happened not only when motor running but also motor stop. We checked connection, value of resitance and grounding calble but did not find any abnormal. This matter happened with many position in our plant. If you have fix it, please share your countermeasure. Thank you so much! Mai Hong Quan. Mr. Vietnam Nghi Son Cement Corporation. [snip] ------------------------------------------------------------------------------------------ |
Last edited by: maihongquan at: 01/29/2021 04:19:01Last edited by: maihongquan at: 01/29/2021 04:23:09Last edited by: Jen_Moderator at: 01/29/2021 11:53:24New subject after splitting. Removed contact data. |
| 1/30/2021 8:24 AM | |
Joined: 5/28/2008 Last visit: 12/29/2025 Posts: 4522 Rating:
Hello, Use Shield cables. It seems that your cables are running within high ammount of noise which negativelly affecting the RTD readings! Hope this helps. |
Ayman Elotaify |
