(0)| 6/27/2014 3:56 PM | |
Posts: 185 Rating:
But where I can see the value of counting? Because it depends of the cyclic OB, the scan cycle, and the value wil not be the real one. |
| 6/27/2014 4:48 PM | |
Posts: 5225 Rating:
Attached some homework. w AttachmentEXTRACT_Easy Book Manual (A5E02486774).pdf (2809 Downloads) |
| 6/28/2014 3:21 PM | |
Posts: 185 Rating:
Yes, I have read this example before, bt it´s not 100% clear. There are a lot of examples here, but al of them only bring me to confusion. |
| 6/28/2014 3:51 PM | |
Posts: 5225 Rating:
As a show of good faith to you, I am willing to give you a push. I am unsure on where your experience level is, so forgive me if I give you info that is trivial to you. Please see attached x3 PDF files zipped Please work through these. Then create a TIA project that uses an S7-1200 PLC. Enable and set up in the hardware configuration one of the HSCs. Next make a call with the "CTRL_HSC" inside OB1. Write variables inside this block what you think you need. Publish the project file here (without password please). State for us which HSC you have used. After this we will give you indications on how to use the HSC with some maths. I hope to receive your positive response. w AttachmentHSC_notes.zip (1991 Downloads) |
Last edited by: William B. at: 6/28/2014 10:06 PMPassword removed from ZIP file. |
