2/26/2009 2:13 PM | |
Posts: 101 Rating:
There are many different ways to do this function. You will need to use the free function blocks within the drive to configure you're start stop circuit. The free function blocks can be found in the Masterdrive compendium https://support.automation.siemens.com/GB/skm/frameset.asp?url=%2FGB%2Fllisapi%2Edll%2F13472409%3Ffunc%3Dll%26objId%3D13472409%26objaction%3Dcsopen%26skm%3D1%26lang%3Den%26query%3Dmasterdrive%26ehbid%3Dhtml%255F76%252Fehb%252F13472409%252Ehtm%26nodeid%3D13472490&Query=masterdrive&SearchArea=hb&id=13472409&F11Marker=true&siteid=csius&query2=&modelled=&lang=en You can also make use of the BICO dataset changeover (P590)which can act as a local/remote switch. An additioal input to the drive will be needed for this though. |
