(0)| 8/3/2021 6:06 AM | |
Posts: 19 Rating:
I have Siemens master drive 6SE7138-6EG62-3BA0-Z 500 KW and Motor of 470 KW. This motor is running with impeller with damper control with without encoder. I wan to know can F015 be resolved by replacing any card . considering Load is normal and all parameters are ok ------------------------------------------------------------------------------------------ |
Last edited by: mosi_0333 at: 08/03/2021 06:09:56Last edited by: mosi_0333 at: 08/03/2021 06:14:09Last edited by: Jen_Moderator at: 08/03/2021 11:10:44New subject after splitting |
| 8/3/2021 7:35 AM | |
Posts: 8092 Rating:
Hello, P583 is source parameter to enable flying restart, & p572 is source parameter for CCW sequence disable. Please refer attached sheet for setting parameters to enable flying restart. AttachmentFlying restart.pdf (866 Downloads) |
