(3)| 8/24/2021 9:52 AM | |
Posts: 8092 Rating:
Please refer attached sheet.
Attachment840 D NC___PLC_Reload.pdf (541 Downloads) |
| 8/24/2021 1:24 PM | |
Posts: 8092 Rating:
Hello, Please clear NC/PLC first (please refer attached sheet). After you clear NC/PLC, 7 segment on NCU should display 6 & no RED LED should be ON. Please read & follow it carefully & observe the results.Then try to reload NC/PLC. You must get healthy system & then only reload NC/PLC data. Attachment840d PL NC___PLC_Data_Clear & restore procedure.pdf (530 Downloads) |
| 8/25/2021 10:38 AM | |
Posts: 8092 Rating:
You mentioned about HDD failuer & you loaded GHOST image. Please check HDD compatibility & loading of successful image. |
