(0)| 2/7/2022 3:26 PM | |
Joined: 2/17/2020 Last visit: 1/21/2026 Posts: 1251 Rating:
Hi Kwate, Welcome to the forum! In this case, I would try to reset the HMI panel to factory settings, following this FAQ. Does the same thing happen after the reset? |
A rating will be well appreciated. |
| 2/9/2022 9:03 AM | |
Joined: 8/3/2009 Last visit: 1/21/2026 Posts: 16653 Rating:
Hello unfortunately in most cases if only the Siemens Startup Logo (at Comfort Panels) appears then you cannot perform a reset to factory settings any more... (perhaps but often not) If the Reset doesn´t work then -> https://support.industry.siemens.com/cs/ww/en/view/22639376 Bye Murof |
