(0)| 12/23/2020 6:17 AM | |
Posts: 2 Rating:
Hello... i have tp177b 6" DP mono. I tried to backup with MPI cable and setting address= 1 for mpi on the TP177B And prosave but connection is failed. try with address 2,3,4,5, etc still connection failed. Can you help me? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 12/23/2020 06:18:48New subject after splitting |
| 12/23/2020 9:06 AM | |
Joined: 2/6/2015 Last visit: 12/18/2025 Posts: 80 Rating:
Hi hcdsp13, Firstly you should verify the bus address for the HMI. Go to "Control Panel" - "MPI/DP Settings" as you can see at this link: Changing MPI/DP Settings https://support.industry.siemens.com/cs/ww/en/view/21084461/10983236619 Best Regards, CGA81 |
| 10/26/2022 9:23 AM | |
Posts: 8171 Rating:
New question published by ruslan.k is split to a separate thread with the subject MP277 Touch 8": Backup with MPI Cabel. Best regards |
