(0)| 1/11/2023 10:55 AM | |
Posts: 234 Rating:
Hi! You probably find useful the following FAQ from the Siemens official web: How do you create dynamic text lists in WinCC (TIA Portal)? In the following link to the TIA Portal Professional V17 manual you can find more information on how to work with text list that may also help you: |
| 1/17/2023 12:49 PM | |
Joined: 8/3/2009 Last visit: 1/9/2026 Posts: 16629 Rating:
Hello Sergey_78 you could use a combobox object in your screen. at the screen open event you can rund an initial script to fill the entries. If a value or a text changes you can also use a script on the object itselfe with tag triggers to update the entries. something like this LINK A dynamic entry like in WinCC Comfort/Advanced is not possible with textlists. Bye Murof |
