(0)| 1/16/2023 4:48 PM | |
Joined: 5/30/2022 Last visit: 1/7/2026 Posts: 634 Rating:
Hi Masood_Es, I have the following questions: 1- Check if it happens with a new basic project? If so, I recommend you to repair the installation and update to the latest available update: Updates for STEP 7 V16, S7-PLCSIM V16 and WinCC V16 If you continue the same: 2- Have you changed the name of the PC since you installed WinCC Prof? If not: 3- Delete the IM folder: How do you delete the IM folder of your TIA project? If it does not work part of a clean Windows image
If this information really helps, you could use the Rate function. |
| 1/17/2023 6:42 AM | |
Joined: 9/8/2015 Last visit: 8/23/2025 Posts: 123 Rating:
I probably changed the name of my computer! What should I do in this case? |
| 1/17/2023 12:35 PM | |
Hi Masood_Es, In this case the solution is: - Installation of WinCC Runtime Professional |
