(2)| 3/14/2023 12:01 PM | |
Joined: 5/30/2022 Last visit: 1/7/2026 Posts: 634 Rating:
Hi budiman.chandra, For WinCC Professional the Sm@rtClient View object is not available as you can see in the following link: Objects for WinCC Runtime Professional The only way is to run the Sm@rtClient application externally from WinCC.
If this information really helps, you could use the Rate function. |
