(0)| 6/29/2023 12:40 PM | |
Joined: 5/7/2019 Last visit: 12/19/2025 Posts: 4 Rating:
HI , KTP700 Basic PN,view is vertikal and my setting button is not responsive, how to return screens to normal_ Thanks |
| 6/29/2023 2:17 PM | |
Joined: 5/6/2022 Last visit: 1/21/2026 Posts: 589 Rating:
Hi Lazar1., To return it to factory settings and reset it, you can do it via USB. Here is a link to a FAQ where you can find all the information you need: "USB Recovery (Reset to factory) Mode for 2nd Generation Basic Panels" I hope it is what you were looking for! Best regards! |
| 6/29/2023 2:54 PM | |
Joined: 8/12/2021 Last visit: 1/20/2026 Posts: 351 Rating:
Hi Lazar1, You can change the orientation of a KTP screen from the menu itself. Take a look at the manual. If this does not allow you to make the change, I suggest you perform a factory reset and update to the latest version of the corresponding panel image
