(1)| 7/18/2023 2:19 PM | |
Joined: 7/19/2022 Last visit: 1/14/2026 Posts: 436 Rating:
Hello, Dynamic text lists can be done but always through variables as indicated in the FAQ: Dynamic text lists in WinCC Comfort/Advanced you have to directly attack the properties of the list to insert values read in the SQL is not possible since it does not support this dynamization, in script, in an Advanced. You could, via script, read these values from the SQL and store them in variables that are used in the dynamic list. |
