(0)| 9/15/2023 12:33 PM | |
Joined: 8/3/2009 Last visit: 1/16/2026 Posts: 16644 Rating:
Hello Masood01 The Basic Panel is not a good choice for this task because you cannot use a report and also noscripts. Wich a Comfort Panel you would be able to do both. So the Panel cannot create this report. On PLc side you can try to use datalogs: https://support.industry.siemens.com/cs/de/en/view/64396156 Bye Murof |
