(0)| 10/26/2023 7:47 PM | |
Joined: 9/16/2022 Last visit: 9/23/2025 Posts: 1 Rating:
Hi everyone!
And yes I also restarted my laptop. ------------------------------------------------------------------------------------------ AttachmentScreenshots.zip (449 Downloads) |
Last edited by: Jen_Moderator at: 10/27/2023 08:41:46New subject after splitting. Quote inserted. Last edited by: Jen_Moderator at: 10/27/2023 08:49:59Embedded screenshots added as .zip file. |
| 10/27/2023 8:45 AM | |
Joined: 5/12/2006 Last visit: 1/16/2026 Posts: 22827 Rating:
check your pg/pc settings in windows control panel if the interface is correct configured |
| 10/30/2023 9:10 AM | |
Joined: 8/3/2009 Last visit: 1/16/2026 Posts: 16644 Rating:
Hello @Rickert078 the local Use has to be in Siemens TIA Engineer and also your use has to have read and write rights to the project path and also to Siemens installation paths I never used V16 in Win11 but it should work as we can see in LINK -> But use the latest Update for your TIA Versions Bye Murof |
