(0)| 2/6/2024 11:12 AM | |
Joined: 5/6/2022 Last visit: 1/15/2026 Posts: 589 Rating:
Hi NIzGood, Could you share with us a screenshot of the exact build version of Windows 11 that you have installed? To rule out compatibility problems. Also, I recommend that you try a new and simple project to see if the same thing happens to you, could you check it? Best regards! |
| 2/7/2024 4:58 AM | |
Joined: 1/28/2023 Last visit: 1/8/2026 Posts: 37 Rating:
Hello, I tried with new projects but the same problem occurs. I'm sharing the winver screenshot. Regards ! |
