(0)| 8/1/2024 1:07 PM | |
Joined: 7/11/2022 Last visit: 11/11/2025 Posts: 59 Rating:
i'm facing the same issue here. Any clue for solution? |
| 8/7/2024 12:07 PM | |
Joined: 8/3/2009 Last visit: 1/19/2026 Posts: 16644 Rating:
Hello I would check the Upd5 for WinCC V8. In the readme there are some information about improved fixes for report system. It worth trying because there is no newer Upd at the moment. if this will not solve the issue you should open a Service Request at Siemens Support. https://support.industry.siemens.com/cs/de/en/view/109818723 Bye Murof |
