(0)| 8/13/2024 10:34 AM | |
Hello Julian; If you do a search for your OP20/240-8 Panel in the search box at the top right of this page, you will quickly find out that it worked with old (and discontinued) S5 systems. These units were discontinued in 1999, and removed from support in 2005. Almost 20 years ago. There are few documents left on the Siemens site on these models. This one gives you the part numbers of ancient memory modules that would have been ordered with a OP20/240-8, but that was in 2006... https://support.industry.siemens.com/cs/ca/en/view/4294133 The software you would have used to do a backup on these operator panels was COM TEXT, the last version of which operated under DOS... Also, a backup of hhis kind cannot be modified, it can only be dowloaded to a panel with hhe exact same part number. If you are really desperate, you should contact Siemens support using a Support Request, you will find a li k at the very top of this page, but I doubt that literature and software for these units could still be found in the Siemens archives. Hope this helps, Daniel Chartier |
