8/26/2024 6:23 AM | |
Joined: 7/10/2024 Last visit: 8/22/2025 Posts: 180 Rating:
Hello! For the Audit Trail configuration it is possible to choose the time base to be recorded. You can choose between local time, utc and poroject settings. I leave you the section of the manual that talks about it, see how it works and see if choosing local time can fix what you want. Configuring the Audit Viewer Control Also, always try to update to the latest version in case you don't have it. |
If you found this post helpul, I'd greatly appreciate your feedback with the rate function |
