10/22/2024 10:53 AM | |
Joined: 7/19/2022 Last visit: 9/1/2025 Posts: 436 Rating:
Hello AutoGen_573531, As you can see in the technical data of the CPU (6ES7517-3FP01-0AB0) the reference 6ES7517-3FP01-0AB0 can only be configured as of TIA Portal V19. In older versions it must be configured under the reference 6ES7517-3FP00-0AB0. There is no problem with this, it will simply show a reference difference message as a warning: Delivery release of the redesigned, fail-safe CPU 1517F-3 PN/DP |
Last edited by: JBS98 at: 10/22/2024 10:53:34If this Information really helps, you could use the Rate function |
