(0)| 10/23/2024 9:42 AM | |
Joined: 5/6/2022 Last visit: 1/22/2026 Posts: 589 Rating:
Hi AutoGen_2242618, In this case, I would recommend you to review the following FAQ that I share with you: I recommend you to review the information in the above link to see if it can help you. Best regards! |
| 10/23/2024 9:44 AM | |
Joined: 4/24/2006 Last visit: 1/23/2026 Posts: 9107 Rating:
Hello, Are you sure it is programmed with a TIA Portal version? Perhaps Step 7 v5.x Simatic Manager is used? (Edit: itafusna was quicker Best regards, Wizard
| 10/23/2024 11:16 AM | |
Joined: 10/9/2024 Last visit: 4/6/2025 Posts: 9 Rating:
Yes. I went through that. but there also no option to know the version of CPU, that connected through CP 343-1 lean. |
