4/4/2024 6:16 AM | |
Joined: 1/31/2019 Last visit: 1/22/2025 Posts: 11 Rating:
OS is Windows 10 PRO, Version 1703, OS Build 15063.0. Where the error code explanation can be found? |
5/10/2024 11:07 AM | |
Joined: 8/3/2009 Last visit: 9/16/2025 Posts: 16436 Rating:
Hello AutoGen_5777385 The same question as before? which OS do you use exactly ? which WInCC Version do you want to install? Check the compatibility List before: https://support.industry.siemens.com/cs/ww/en/view/64847781 Bye Murof |
11/14/2024 10:09 AM | |
Joined: 10/30/2022 Last visit: 4/22/2025 Posts: 3 Rating:
dear sir, my os is Windows 10 Enterprise 2016 LTSB & i am trying to install v 8.0 but facing the same error |
