(1)| 1/28/2025 11:34 PM | |
Hello Davinator; Siemens proposes a Toolbox for HMI United Comfot panels where there is a section discussing keyboards. See section 13.1. Check it out and see if it provides an answer you can use. https://support.industry.siemens.com/cs/ca/en/view/109770480 Hope this helps, Daniel Chartier |
| 1/29/2025 5:52 AM | |
Joined: 1/21/2013 Last visit: 1/19/2026 Posts: 4414 Rating:
Hi Davinator, You are right, the Unified System still has a lot of gaps compared to the old WinCC Basic/Comfort panels. However, each update will reduce these gaps. Regarding the numeric keypad, just use the current V20 image version. The numeric keypad was introduced with this version. Since the image versions are backward compatible, you can also use the V20 image with a V19 or V18 project. Kind regards |
