(0)| 2/7/2025 4:12 PM | |
Joined: 5/29/2024 Last visit: 1/21/2026 Posts: 123 Rating:
Hi JC! In WinCC Unified, layers are used to organize and manage the visibility and order of objects within a screen. Here’s an overview of how layers work and how you can use them effectively:
Here you can find more information: -> SIMATIC HMI WinCC Unified Engineering V18 > Using layers Hope it helps! |
| 2/7/2025 4:43 PM | |
Joined: 2/7/2012 Last visit: 9/2/2025 Posts: 58 Rating:
Thank you for the quick and eductional response. With the above being true, and Layer 31 is Foreground, should my screen template be in layer 31 with all screens and non-template objects be in a lower numbered layer? Thank you, JC |
