(0)| 2/12/2025 7:46 AM | |
Joined: 1/21/2013 Last visit: 1/20/2026 Posts: 4416 Rating:
Hi Geralt, I did some tests on the described behavior and you are right, the preview is not correct. It works as long as the faceplate is only used once within the screen. If it is used more than once, the properties of the first use are used. In the case of a grid, only the alternate background color of the first use is used, in the case of a gradient, both colors of the first use are used. However, posting a topic here in the forum does not create a bug for the developers. To let the developers know about this behavior, please create a support request. Kind regards |
| 2/12/2025 9:49 AM | |
Joined: 1/27/2011 Last visit: 9/1/2025 Posts: 7 Rating:
Hello Stefan, Thanks for your reply. I've opened a service request, let's see what they say. Best regards, |
