(0)| 10/17/2024 9:16 AM | |
Joined: 8/3/2009 Last visit: 1/16/2026 Posts: 16644 Rating:
Hello AutoGen_8056590 It did a quick test in my V17 Upd6 and it works as it should... Which Update do you have installed? Can you send us details from your Engineering? Try also a Reset of the temp files and test it again: https://support.industry.siemens.com/cs/de/en/view/109778709 Bye Murof |
