(0)| 3/20/2025 10:57 AM | |
Joined: 5/6/2022 Last visit: 1/15/2026 Posts: 589 Rating:
Hi Halilkyn, I understand that you have reviewed the following FAQ for login and logout for WinCC Unified? Comment us to if not check for possible problems similar to the one you are experiencing. Best regards!
| 3/20/2025 11:07 AM | |
Joined: 12/8/2022 Last visit: 11/19/2025 Posts: 10 Rating:
Hi, yes, I reviewed the FAQ. I am trying to log in but it doesn't work. I wanted to simply logoff but it doesn't work. What am I missing? I re-installed the certificate. (I chose Local Users.) I added users to the project and gave them different permissions. I turned on and off automatic login.
| 10/9/2025 7:55 AM | |
Joined: 2/16/2022 Last visit: 11/14/2025 Posts: 1 Rating:
Was having the same problem. Changed the Event from ‘Press key’ to ‘Press’ and it worked. |
