(1)| 3/30/2023 8:40 AM | |
Joined: 1/21/2013 Last visit: 1/21/2026 Posts: 4421 Rating:
Hi jofi,
You are right, Element.requestFullscreen() would help to solve your requirements. However, it is not supported in WinCC Unified. But maybe the Web-Toolbox_CWC will help you, but to be honest I have not tried it yet. Kind regards |
| 3/30/2023 1:30 PM | |
Joined: 3/11/2012 Last visit: 1/15/2026 Posts: 33 Rating:
Thanks. I don't want to limit access by using kiosk-mode so will have to look further into this. |
| 3/29/2025 11:17 PM | |
Joined: 4/30/2019 Last visit: 12/3/2025 Posts: 6 Rating:
Did anyone find a solution to this issue? |
| 4/2/2025 1:10 PM | |
Joined: 8/3/2009 Last visit: 1/21/2026 Posts: 16653 Rating:
Hello SamCarrier check out the WinCC Unified Station Configurator: https://support.industry.siemens.com/cs/de/en/view/109827849 Here you can also work with a Kiosk Mode and also ue a Shortcut for access Bye Murof |
